What sander said. Also you can uncheck the "lock" symbol when scaling and only scale up one or two axes instead of all 3 but I dont' think that will help you. I think you need to scale the cad model.
Hi Katieb,
Thank you for your post.
I am not entirely sure I understand what you mean. Do you want to be able to scale it up and down, but thave the 'wall / brim' remain the same in size?
That is certainly doable, but just not in Cura. You would have to do this in your CAD modeling software.
Sorry - Im not sure how to explain myself.
Yes, I would like to be able to scale the overall width and height of a design without it effecting the wall thickness and brim (the bottom of the cutter).
I use DesignSpark - is it at all possible to do it in that program?
So, I would need to adjust my initial model (lets say its a 3") for the 3.5", 4" and 4.5"? Eugh, that sounds like a lot of work - considering I have hundreds of designs :/
Well, it's the only way to do it really. What you're asking of cura is like putting a shirt in the washer on high heat and ask it to only shrink the left sleeve.
Interesting way of putting it.
Ive worked out that I cant do it in Cura - its just that in design spark, you cant edit the files so I would basically have to re draw them 4 times.
You can do it in Tinkercad I think, I just do not really get what you mean.
Cura can take image files such as a png file (don't recommend jpg as the compression adds lots of noize) and turn that black and white image into a height map such that black lines are tall. This is one way to make cookie cutters. You can switch on brim as well. But it won't let you add supports like you did for that tomato. But I supposed you could do that by adding a gray line to your drawing - then the gray line will be printed at a shorter height (shorter wall).
SandervG 1,522
Hi Katieb,
