does this still work with 2.4 and 2.5 Beta?
Yep. Even works when running it from source. I use the plugin a lot myself, so it's almost guaranteed to work
I asked, because with a lot of organic models I printed lately it doesn't do anything.
If I load a cube and rotate it on its point, it reacts as expected, but if I have an organic model and rotate it in a position where a lot of red shows it does nothing...
The algorithm is not stable. Hitting calculate optimal angle will reposition the model in a different orientation.
Also the starting angle will affect the resulting orientation.
I'm not talking about angle around the Z axis; the model can actually get different orientations around the X and Y axis.
Please make a shortcut in the rotation tool menu, so that you automatically bump into it when you are busy rotating the part yourself.
Also: when is this going to be shipped with Cura?
Huh. Odd. Do you have an example of one of those models?
I had an older version installed, the most recent one fixed the problem...
works great!
Hi @nallath, I am trying to use the auto-orient plugin in my CuraEngine source, executing from the command line. Not sure how could I integrate the plugin functionality in the engine.
Edited by DevangIt's not intended to be used without the front end. You could try and see if you can get the meshTweaker (my plugin wraps that) to work in command line.
nallath 844
Most of the credit goes to Christoph. I just made sure it worked with Cura. It only took me about ~2 ish hours to build.
ChrisSalzburg 12
I'm glad you like it! I'm still about to improve the algorithm, so if you have troubles or have found insufficient results, please let me know!
drayson 74
@chrissalzburg, danke für deine initialarbeit!! Gruß aus Graz :-)
peggyb 169
