Daid 260 Posted October 21, 2016 in Inside the Ultimaker 3 - Day 3 - Remote access (part 2) (edited) This is day 3 of "Inside the Ultimaker 3", Remote access part 2 - Other days: Day 1 - GCode Day 2 - Remote access part 1 - Welcome back. Yesterday we look at accessing data from the printer. Today we will look at changing data in the printer from remote access. - This is a whole lot more technical and complex then just accessing data. The reason for this is security and mistakes. First off, you might not want everyone on your network to start/abort/pause prints. And you might, by mistake, control a different printer then you wanted. Think excidental use is uncommon? It happened at our office during development. And think how often you send something to a 2D printer to find it at a different printer then you expected. Security! First off, we had quite a few discussions about this at the office. As you need to have the proper trade-off between security and ease-of-use. Also, security is not an easy subject. Things that might look secure don't have to be. Things that are secure might be a pain to use. - So, we made the following decisions: Reading of data is always possible. To make monitoring of printers easy, and while you can access camera feeds and print head positions. It's not possible to get the exact gcode file out of the printer. Thus the model is still quite secure. Any "change" in the printer requires authentication. A change can be starting a print, aborting a print, or even changing the LED colors. Authentication is done by a pairing mechanism. So your printer and Cura, a phone app, or any application you want need to "pair up". Most of this is invisible to the user. Physical access is access. So if you can touch the printer you should also be able to pair up. Multiple applications/devices can be paired with the printer at the same time. The end result of this means that if you have an Ultimaker 3. And you connect with Cura for the first time, you need to say on the printer "I allow this Cura to use this printer". - On the technical side, this means any REST request to the printer that is not a HTTP GET request requires this pairing to be done correctly. Pairing, under the hood. The pairing process is actually a multi step process. These steps are: The application request a new ID/KEY combination from the printer. It does this with the name of the application and the name of the user that wants to access the printer. The printer returns this new ID/KEY combination to the application. The printer shows the dialog with DENY/ALLOW Until the user has selected ALLOW on the printer, this ID/KEY combination is not valid. The application keeps checking if the user selected allow or deny on the printer. Once ALLOW is selected, the ID/KEY combination can be used as username/password combination for HTTP Digest. HTTP Digest... The nice things about standards is, that you have so many to choose from. For security we looked for something that was quite easy to implement, but offered the security we needed. While we did look at HTTPS, the problem there is that you need certificates, and which the openness of the devices this became complex really quick. - So, we looked at RFC 2617, known as HTTP Digest authentication. This standard on top of HTTP allows for easy username/password checking, while being protected against: Man-in-the-middle attacks Eavedrop attacks Replay attacks However, there is one problem with the standard. It says that you can always fall back to lesser secure modes. Which offer limited or no security at all. So, we chose to implement one of the strongest forms of HTTP Digest, and REQUIRE it, instead of making all the security features optional. - This all sounds very complex. However, if you are a software engineer and you want to talk to the printer. You most likely have a library that will solve this for you. However, as suggested in the other topic, postman is implements Digest auth as such a low level that it is impossible to get this to work consistantly. The HTTP librart of QT has no problem with this. The "requests" library from python can also be used with almost no effort. I will provide an example in a bit. The cop-out If you are developing, and the security is in your way and you want to deal with it later. There is a cop-out. All this complex digest and pairing is disabled in the WiFi setup right now. As you are a local hotspot. This also made it easier to develop the WiFi setup. So, for quick testing, you can start a WiFi setup, and connect to the local hotspot, and talk to the printer without any security. The real thing Finally, some actual things. There are 3 API parts that are important at first. They are: /api/v1/auth/verify: Used to check if your authentication id/key is still valid. This is the only API which requires authentication on a GET request. If you go here with your browser, you will get the username/password popup. /api/v1/auth/request: This is used to setup a new pairing request. This needs to be done as a POST request, with 2 parameters "application" and "user". The API will return a JSON result with an "id" and a "key". This is your username and password for the HTTP Digest. However, this isn't valid till you pressed "ALLOW" at the printer. If you press "DENY", this combination of ID/KEY is discarded. /api/v1/auth/check/{id}: This can be used to check the status of your new request. {id} should be filled with the result from the /api/v1/auth/request call. The result will be one of: "unauthorized", "authorized" or "unknown". "unauthorized" means that the user pressed "DENY" and you can discard the ID/KEY. "authorized" means "ALLOW" is pressed and you can now start using this ID/KEY. "unknown" means that the user hasn't done anything yet and you should try again. Side effect: Currently, the printer only allows for 1 pairing request at the same time. If you send a 2nd request, the first one is denied automaticly. - So, in pseudo code: if no (id, key) or "api/v1/auth/verify" == "unauthorized" then id, key = post("api/v1/auth/request", application="Test", user="Daid") while "api/v1/auth/check/" + id == "unknown" do sleep 1 second end if "api/v1/auth/check/" + id == "unauthorized" then abort: failed to pair up. endend//We now have a valid id/key combination. All that, just to pair up. Doing actual things Still following me? Good. If not, sorry, this is all very technical. I will provide example code at the end. Now, we want to do thing. And there are quite a few things we can do with the API. I will cover a few things. Changing the printer name. Why? It's the easiest API. Changing the LED colors and heating up things. Starting a print job. Why? It's the most important API. Aborting a print job. After you started it, you might decide that you do not want it. (Or the print could be failing. But that is rare right?) Change the name Remember from day 1, the printer name was read at /api/v1/system/name. Now, we can set the printer name the same way, but instead of a HTTP GET, we need to use a HTTP PUT. Now, all our APIs require JSON as input. This means a few things, the data in the PUT request needs to be valid JSON. And the Content-type header of the request needs to be set to "application/json". If we want to set our printer name to MyUltimaker3, we get a request that looks like this: PUT /api/v1/system/name HTTP/1.1Host: 10.180.1.209Connection: keep-aliveAccept: */*User-Agent: python-requests/2.11.1Accept-Encoding: gzip, deflateContent-type: application/jsonContent-Length: 14Authorization: Digest username="2af8417b8501e0422e191d5fbe64209e", realm="Jedi-API", nonce="76684432bdb9a1a386a877e41468a681", uri="/api/v1/system/name", response="50da68df53c0eeb9906212560b0077aa", qop="auth", nc=00000003, cnonce="b2316951bb03e010""MyUltimaker3" This is an actual request that I logged. My auth ID is "2af8417b8501e0422e191d5fbe64209e" which you can see in the Authorization part, my auth KEY is "f9a43169c49bb9e81d670c946d6358dac428b820e0d9676e15b63bdcf57be45f", which you cannot see, and is used to generate the "response". Placing this here to possibly assist in debugging if you are doing your own implementation of HTTP Digest. The printer name is under some restrictions. So your printer might not always accept the new name. Changing the LEDs and heating up. Important note, in firmware versions 3.4.x these APIs are broken. They should be fixed as of firmware version 3.5.x Changing the temperature. This is easy, we want to set the target temperature. The APIs for this are: /api/v1/printer/heads/0/extruders/0/hotend/temperature/target /api/v1/printer/heads/0/extruders/1/hotend/temperature/target /api/v1/printer/bed/temperature/target And, just like the name, you can just put a value into it to change the target. As this needs to be in JSON format, it needs to be a number without quotes, while the name was a string and thus needed quotes. Setting the LED brightness and colors can be done in a single call. There are the APIs: /api/v1/printer/led /api/v1/printer/led/brightness /api/v1/printer/led/saturation /api/v1/printer/led/hue The last 3 set each value seperately, but the first one can be used to set all 3 in one go. You do this by sending a single json dictionary containing the proper key/value combinations to /api/v1/printer/led. Once again, this needs to be a HTTP PUT request. Example: {"brightness": 50.0, "saturation": 20.0, "hue": 100.0} Note, the current implementation of the API returns no status when you do this. So you do not know exactly if the request was accepted. Starting a print Starting a print is the most complex call there is, as you need to send a multi-part file upload. If you are not using a library for HTTP communication. Forget about it. Else, it's easy, just do a HTTP POST request with a file upload to /api/v1/print_job, with the name of the file parameter to "file". Abort/pausing a print job You might want to abort or pause a print job remotely. This is all done trough the /api/v1/print_job/state API. Once again with PUT requests. You need to PUT the new state you want into this state API, in the form {"target": "new state"}. There are 3 possible things you can PUT here. abort, requests the print to be aborted. pause, if the print isn't paused it will do so now. print, if the print is paused, it will resume printing. Note that this API in the current implementation always reports no content. So you need to poll the state to see if you request was actually honored. Wrapping it up. I'll just finish with my python3 code that can talk to the Ultimaker 3. You can use this as an example, or if you make an open-source product you can use it directly. ## This program is free software: you can redistribute it and/or modify# it under the terms of the GNU Affero General Public License as# published by the Free Software Foundation, either version 3 of the# License, or (at your option) any later version.# # This program is distributed in the hope that it will be useful,# but WITHOUT ANY WARRANTY; without even the implied warranty of# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the# GNU Affero General Public License for more details.# # You should have received a copy of the GNU Affero General Public License# along with this program. If not, see .import requestsimport jsonimport osimport time## Ultimaker 3 API access class.# Allows for access of the Ultimaker 3 API with authentication.# Uses the python requests library to do the actual http requests, which does most of the work for us.class Ultimaker3: # @param ip: IP address of the printer # @param application: name of the application in string form, used during authentication requests and is shown on the printer. def __init__(self, ip, application): self.__ip = ip self.__application = application self.__session = requests.sessions.Session() self.__setAuthData("", "") # Set new authentication data, authentication data is send with each HTTP request to make sure we can PUT/POST data. def __setAuthData(self, id, key): self.__auth_id = id self.__auth_key = key self.__auth = requests.auth.HTTPDigestAuth(self.__auth_id, self.__auth_key) # Load authentication data from a file. If this file does not exists, or the data in it is invalid, we request a new authentication set and store it in the file. def loadAuth(self, filename): try: data = json.load(open(filename, "rt")) self.__setAuthData(data["id"], data["key"]) except IOError: self.__checkAuth() self.saveAuth(filename) if not self.__checkAuth(): self.saveAuth(filename) # Save the authentication data to a file. def saveAuth(self, filename): json.dump({"id": self.__auth_id, "key": self.__auth_key}, open(filename, "wt")) # Check if our authentication is valid, and if it is not request a new ID/KEY combination, this function can block till the user selected ALLOW/DENY on the printer. def __checkAuth(self): if self.__auth_id == "" or self.get("api/v1/auth/verify").status_code != 200: print("Auth check failed, requesting new authentication") response = self.post("api/v1/auth/request", data={"application": self.__application, "user": os.getlogin()}) if response.status_code != 200: raise RuntimeError("Failed to request new API key") data = response.json() self.__setAuthData(data["id"], data["key"]) while True: time.sleep(1) response = self.get("api/v1/auth/check/%s" % (self.__auth_id)) data = response.json() print(data["message"]) if data["message"] == "authorized": print("Authorized.") break if data["message"] == "unauthorized": raise RuntimeError("Authorization denied") return False return True # Do a new HTTP request to the printer. It formats data as JSON, and fills in the IP part of the URL. def request(self, method, path, **kwargs): if "data" in kwargs: kwargs["data"] = json.dumps(kwargs["data"]) if "headers" not in kwargs: kwargs["headers"] = {"Content-type": "application/json"} return self.__session.request(method, "http://%s/%s" % (self.__ip, path), auth=self.__auth, **kwargs) # Shorthand function to do a "GET" request. def get(self, path, **kwargs): return self.request("get", path, **kwargs) # Shorthand function to do a "PUT" request. def put(self, path, **kwargs): return self.request("put", path, **kwargs) # Shorthand function to do a "POST" request. def post(self, path, **kwargs): return self.request("post", path, **kwargs) It's a very basic wrapper around the very new "requests" library for python. But it helps in setting up the authentication. Example usage: api = Ultimaker3("10.180.1.209", "Test script")api.loadAuth("auth.data")# Get all the system datasystem = api.get("api/v1/system").json()print(system["name"])# Change the system nameresult = api.put("api/v1/system/name", data="MyUltimaker3")print(result.json())# Set the target hotend temperature to 100C, and then back to 0.print(api.get("api/v1/printer/heads/0/extruders/0/hotend/temperature").json())result = api.put("api/v1/printer/heads/0/extruders/0/hotend/temperature/target", data=100.0).json()print(api.get("api/v1/printer/heads/0/extruders/0/hotend/temperature").json())result = api.put("api/v1/printer/heads/0/extruders/0/hotend/temperature/target", data=0.0).json()print(api.get("api/v1/printer/heads/0/extruders/0/hotend/temperature").json())# Change the LEDsapi.put("api/v1/printer/led", data={"brightness": 50.0, "saturation": 20.0, "hue": 100.0})# Start a print job.result = api.post("api/v1/print_job", files={"file": ("UM3_Box_20x20x10.gcode", open("UM3_Box_20x20x10.gcode", "rb"))})print(result.content)# Pause the printapi.put("api/v1/print_job/state", data={"target": "pause"})# Resume the printapi.put("api/v1/print_job/state", data={"target": "print"})# Abort the printapi.put("api/v1/print_job/state", data={"target": "abort"}) - - Disclaimer: Any information presented here could be wrong. I did my best to proof read everything, but it could confict with official statements and the actual behavior of the printer. This post is purely informative and does not necessary reflect the official view of Ultimaker. Edited October 28, 2016 by Guest 8 Share this post Link to post Share on other sites
neotko 1,354 Posted October 21, 2016 in Inside the Ultimaker 3 - Day 3 - Remote access (part 2) Thank you for the info @daid !! Cool stuff. 3dprint time lapses could be so cool with leds changing over time and custom scrips controlling a camera and leds. Thanks! Share this post Link to post Share on other sites
kitusmark 0 Posted October 21, 2016 in Inside the Ultimaker 3 - Day 3 - Remote access (part 2) Wow. Just awesome work! Share this post Link to post Share on other sites
nallath 528 Posted October 21, 2016 in Inside the Ultimaker 3 - Day 3 - Remote access (part 2) Wow. Just awesome work! I'm fairly happy with how the API turned out. I'm also quite curious as to what people will do with it. Share this post Link to post Share on other sites
Daid 260 Posted October 21, 2016 in Inside the Ultimaker 3 - Day 3 - Remote access (part 2) I'm fairly happy with how the API turned out. I'm also quite curious as to what people will do with it. Well, now that I've been testing some odds and ends that we where not using yet, I've noticed a few things that we can improve and fix on. Especially status reporting on calls is a bit "random". For example, the result of setting a name is: {'message': " set", 'result': True, 'return_value': 1} or {'message': " set", 'result': True, 'return_value': 0} Depending on if it changed the name or not. While sending an abort/pause always comes back with an empty reply. Setting a single property of the led returns something that looks like setting the name, but setting them all at once returns an empty result like the abort/pause... I think our data querying part, and the data setting part are quite good, but the reporting back from certain calls is a bit messy. Share this post Link to post Share on other sites
nallath 528 Posted October 21, 2016 in Inside the Ultimaker 3 - Day 3 - Remote access (part 2) I think our data querying part, and the data setting part are quite good, but the reporting back from certain calls is a bit messy. Yeah I agree. I focused more on getting the initial structure right and not so much on consistent reporting. Share this post Link to post Share on other sites
Daid 260 Posted October 28, 2016 in Inside the Ultimaker 3 - Day 3 - Remote access (part 2) Just made a small fix to the example script, authentication would not be saved if you needed new authenication because for example, you started to talk to a different Ultimaker3. 1 Share this post Link to post Share on other sites
Floftw 0 Posted August 21, 2017 in Inside the Ultimaker 3 - Day 3 - Remote access (part 2) Hey, really nice work ! Maybe you can help me with my problem. When i want to change the printer name the PUT request is working but i get from the printer: body: {"message": "Authorization required."} How can I send him the authentication id and key. I am trying to set up a nodeJS server. Share this post Link to post Share on other sites
jeromechrist 0 Posted October 2, 2017 in Inside the Ultimaker 3 - Day 3 - Remote access (part 2) Hello, I'm using a Ultimaker3 with firmware : 3.7.7.20170627 (latest from stable). I have the following issue when calling GET /printer via a client generated from swagger tools : the Network object returns differs from the spec (returns an object : is an enum in spec), which throws a serialization exception. Is there an updated - correct - swagger doc somewhere ? A nuget package for a c# client ? If not, a github repo where we can contribute ? Thanks ! Share this post Link to post Share on other sites
