ok I'm still dissatisfied.
i tried printing the large volume and honestly, when using dual extrusion, you can't really do that without some form of priming. so disabling the prime tower is not really an option..
@SandervG .. honestly, I think the build volume should be updated on the website. while not technically wrong, it is near impossible to use.
if you substract the priming tower, which you kinda need for PVA, you loose quite the amount of surface. if you use the default settings in Cura, or even the settings you can see, you are about 1.5 to 2 cm away from the specified print volume. that is quite the percentage..
I had to search the community to find out all the trickery i had to do to fit objects in.. and i could not work a prime tower in, which when printing with PVA is not fun, which you could normally fix with the horizontal expansion with support.. which you must also disable..
so while the spec is technically correct (and yes, that's the best form of correct), it is not a realistic build volume..
korneel 175
nevermind, found the solution.. but i don't like the solutions I found :(
