It would be very difficult to make using it more of a pain in the butt. That's more work than using Slic3r to set the layer heights manually, and Slic3r can do it with any FDM printer.
Bad programmer! Bad Job!
Edited by GuestIt would be very difficult to make using it more of a pain in the butt. That's more work than using Slic3r to set the layer heights manually, and Slic3r can do it with any FDM printer.
Edited by GuestI use this in Simplify3D, although it is not automatic. Very practical for boxes with rounded/chamfered edges. It would be cool if given a set of settings the slicer could select by itself the one with highest quality while retaining a sensible speed. The same goes with more adaptive control of the infill.
This is no good for smoothing as printing anything below .06 would be a nono for me eitherway regardless. Looks ok in principle (if printers layed down square filament, but unfortunately its edges are curved not cubic) hence for FDM this is a no.
neotko 1,415
