fbrc8-erin 316
Hi, MuffinKiller86,
Regarding the print time, you're going to see longer times for dual extrusion prints compared to single extrusion prints the same size because every time the printer switches from one material to the other, it's going to take time to cool down the first nozzle and heat the second. It's designed this way to help prevent oozing across the model, but it does add more time to the printing.
Can you use less infill? Or go into the advanced settings and increase the layer height? I printed an model based off Escher's Relativity earlier this week and took the time down from about 3 days to 2 days by increasing from a .15 layer height to .2 and it still came out pretty well.
The image isn't coming through for your print, but one thing I've noticed with the UM3, is that I'm getting better results using a glue wash on the bed. With the UM2/UM2+ I very rarely used glue on the bed with PLA, but I'm finding it does make a difference when printing on the UM3.
DidierKlein 730
Please use the forum gallery to upload images!
(First image is invalid)
Hard to help you!
