Interesting thread
I was running Cura 15.04.2 for these prints and the newer Cura, with Coasting, might help.
Interesting thread
Hi LePaul,
This one is interesting.. Can't help but, I do not believe this is a "random" blobs placed with this precision on two of our standard test object. No Way..
Why not try the flow test, as this will show "the error" more easy for us to investigate?
Thanks.
Torgeir
Which flow test?
Yes, interesting that both prints in different materials present the same issue
Hi LePaul,
I'm thinking about this one:
https://www.youmagine.com/designs/test-print-for-ultimaker--2
Hmm., do not know if this is to much for a UMO, but you'll see.
This is the little single layer tube, that’s used for flow test, this blobs should make some interesting pattern in this tube.
Thanks.
Torgeir.
Try printing at half speed. Quality just sky rockets at 20 to 25mm/sec. And make sure ALL printin gspeeds are the same - none of this "infill faster" stuff. Fast travel speed is good but slow printing speed.
I may even try a different nozzle....
Hi gr5 and LePaul,
Even a better idea for sure, go for it, but don't change the nozzle -just one thing at a time..
Good Luck.
Torgeir.
That's good advice
I'll slow it down and see how the blob situation goes.
neotko 1,418
