fbrc8-erin 299
The 2 Cores should always have a height difference of about 1.5mm to prevent the Core that's not in use from running into the print. The left hand Core is static and the right hand Core moves up and down with the use of the switching bay as neotko said.
- 1
neotko 1,417
Is normal. The lift mechanism changes the height of the second core.
