Hi Torgeir,
Thanks for your reply, here are my answers to your questions:
- I'm Using Colorfabb PLA/PHA
- Nozzle temp: standard @ 210 degrees but I went up to 225 and even 230 degrees, achieving slightly better results.
-Nozzle temp seems to be have normal during printing, temp only fluctuates 1-2 degrees from setting.
- Printspeed was 50 mm/sec (20 mm/sec worked a few times for smaller prints)
- Feeder doesn't grind
- Only when feeding new material, sometimes the fever slips/kicks just a little but this can't be heard during printing.
- I'm using the Olsson block with 0.4 mm nozzle.
- Feeder does not seem to find material other than normal during printing.
I hope it can be fixed soon, but I don't know where to start anymore and I'm not able to invest in all sorts new parts so I hope that I can find an "easy" way... :-)
Thanks for your help so far!
Mickael
Hi obus3d,
I'm very sorry to see this, also to hear that you've been struggling for such a long time with this problem.
This is more than "under extrusion", you have some serious error/problem here.
Looks like the skirt is OK. -and the first layer as well..
So first question, what kind of filament are you using here? And what is the temperature setting you're using for this print? Did you monitor the temperature to see that it is correct? This is a low speed print, what speed then?
Then, -during filament insert/feed and extrusion, -there is some signs that can alarm if something is wrong!
This pre feeding with the plastic extrusion out of the nozzle, is it going very fast without any kick back of the feeder? It should continiue with same speed as it started with without any slipping or feedback (assume using 0.4 mm nozzle), can you confirm this?
The question I'm ask here is "valid", -if you're using PLA. PLA is the best filament to use for measuring/testing, -this is also the one that's create less problem in general..
Does the feeder grind your filament, preventing feeding properly?
Yes, sure I'm asking a few question here, but we need some answers in order to help.
Here's many people with lot's of experience, so I'm sure your printer problems soon to be fixed.
Thanks.
Torgeir.
Torgeir 205
Hi obus3d,
Thanks.
Torgeir.
Edited by GuestLink to post
