DidierKlein 729
And what's the layer height?
I've printed with a 1mm nozzle at 30mm/s i think with 0.5mm layer height.
This makes a volume of 1*30*0.5 = 15mm3/s which is i think in the average of what you can extrude with a UM2. I've done much higher (30mm3/s).
What is the material? PLA? How is the Teflon?
Torgeir 264
Hi leon_knook,
Very interesting.. What kind of filament type are you using here?
Ehmm, 24 m/s -must be a world record , so I'll assume 24 mm/sec. right?
Anyway, pretty amazing for a UM2, with a 1.00 mm size nozzle.
You could isolate the Olsson block, and/or use the next up heater element, more energy for melting the filament..
Last fix, will be to reduce the friction in between bowden tube and the filament, but here you'll need a few more step to do, but the feeding pressure will increase!
There is a limit for such high demand feeding. But not sure the limit.
Some more info pls. (Effect of used heat element and type of filament.)
Thanks.
Torgeir.
