But if you are just pointing out a bug then I've seen this bug also. I know - it sucks.
Yes, I need this bug to be cleaned because it's annoying me for a much more complex print that I cannot rotate.
For now use meshmixer supports:
http://www.extrudable.me/2013/12/28/meshmixer-2-0-best-newcomer-in-a-supporting-role/
I recommend a 7 to 1 ratio of base to height so if your supports are 70mm tall your support base should be around 10mm wide.
Thank you, but I'll wait for a Linux version
For now I forwarded this thread to the github CuraEngine issue tracker:
https://github.com/Ultimaker/CuraEngine/issues/421
Thanks again
This bug is fixed in Cura 2.4, which will be out in a month or so.
The bug was in towers which would get introduced for small layer parts even for top surfaces. These would then be introduced to the support of every layer below.
I think you can avoid this bug by disabling the Use Support Towers setting.
I am not using towers.
I tried conical support without success
May I try the current CuraEngine to see if the problem remains ?
Did you try it ?
Is it difficult to run the git version on debian 8.2 ?
Thanks
It's not so hard to get the source-version running on Debian. Take a look at the cura-build repository here: https://github.com/Ultimaker/cura-build#ubuntulinux
It's tested most often with Ubuntu but Debian should work just as well. You might run into a few missing dependencies or minor problems with some of the libraries it wants to compile, which will make take a sufficiently knowledgeable programmer a few hours to complete the build.
We're also quite near to releasing a public beta for 2.4. If you're slow, we'll catch up with you!
OK I'll give it a try if needed. For now I will wait for 2.4
I found two work arounds for this bugg in 2.3.1:
- flatten horizontally the top surfaces
- thicken the model (plane or beam or whatever)
Thanks for your work
This slicer is giving very good results
I upgraded to 2.5 these days
To me, the bug is only partially fixed. Here is the remaining problem:
As shown higher in my image: with an overhang angle set to 40 degrees, the support on the left side was getting down to the build plate. But it should not, it should stop and rest on the intermediate plane.
With version 2.3 you can see that only one half of the left side go through the intermediate plane.
With 2.5 all the left side support goes through it, down to the build plate, which is worse.
As I understand there's no need to make the support forcibly touch the build plate.
Best regards and thanks for the effort
Edited by GuestOK solved with version 2.7
He says almost a year later...
gr5 2,330
Well, hopefully you thought of this, but if you rotate it 90 degrees you won't have any overhangs anywhere. Cura lets you do the rotation - just click, then click on rotate icon in upper left area then drag it by 90 degrees.
But if you are just pointing out a bug then I've seen this bug also. I know - it sucks. I don't think this part actually needs support in this position but I would never print it in this position anyway as it would fall over so easily. One would need lots of brim.
