been printing at a slow speed. temp 220*. have pushed the temp up to 235* same issue.
the grind wheel is eating it. theres dusted filament in the tube. which i have to Keep cleaning - again i have adjusted the tension.
filament sides easily through the tube with no issues.
This is an on going issue that keep happening as a constant and honestly i'm sick of it.
will post pics later on one i go back to the printer as i have a sledge hammer to hand and yes, it has gone through my mind.
illuminarti 18
Sorry to hear about your problems... Here's a few things to check:
1) it could be a problem at the hot end that is making the extruder work too hard. What temperature are you printing at? When grinding occurs, can you manually push the filament through the tube fairly easily?
2) have you checked the diameter of your filament? Does it slide trough the tube easily when pushed by hand.
3) could you post some photos of your extruder, open and closed so folks can see if anything looks wrong?
After all that if you're still interested in selling, I might be interested... :-)
