Somethings just are not very printable. Every manufacturing process has its limitations.
Have you tried adding "helper disks"? You can add them to a print right in the slicer software. The slicer then merges the objects and prints them as one part. Then you have to cut them off with a sharp knife or clippers. You can also use these on corners to help keep parts from warping off the bed.
[print=3440][/print]
I was pretty surprised that this actually worked! We almost didn't try it because it didn't fit in the printer in a normal way. We had to stand this up on just one edge and add a bunch of helper discs.
You could also try cutting the model in half and putting the two cut faces on the bed.
https://blog.adafruit.com/2014/07/31/split-large-designs-into-printable-parts/
gr5 1,872
A picture would be helpful. Usually you can rotate it so that 3 points touch the plate.
Anyway, I almost always create my own supports in CAD instead of using a slicer. However if you aren't the designer then I recommend meshmixer. It's free. Here's an article about using it for support:
http://www.extrudable.me/2013/12/28/meshmixer-2-0-best-newcomer-in-a-supporting-role/
