Besides that, the layers also seem a little bit under extruded, and it looks like you could bend your fanshrouds a little bit more inwards to close the gap, like in this photo.
Neo also had a valid tip, check out the guide. It is a pretty good guide.
What material you have used, and at what temperature and speed are you printing?
Have you ever replaced your PTFE/TFM coupler, or do an Atomic Method?
neotko 1,418
Check 'shifting layers'
http://support.3dverkstan.se/article/23-a-visual-ultimaker-troubleshooting-guide#shifted
