It's only great in theory.... he states it does not work.... and we already know pla/pva bonding is not the best, therefore the horizontal expansion is on by default in cura.
I wonder though if it might be a good idea to try on nylon/pva as the bonding is much better there.
bjorn 9
Well since nobody seems to have experience with this, I'll share my own![:)](//content.invisioncic.com/ultimake/emoticons/5a33abdf6d109_1f60acopy.png)
The PVA supports stick very poorly to the PLA 'base' of the supports. In my case this resulted in loose PVA material contaminating the print. I stopped the print at that point, but I doubt if the supports would have worked at all. I forgot to take a picture, but thus far this seems not successful.
SandervG 1,521
Hi @Bjorn, thank you for sharing your methods. Am I right in understanding that the biggest part of your supports (everything except for the roof), is print with your build material, and only the roof with PVA?
That is a great way to save materials, and time since you don't have to switch heads that often. But it only works with supports on the outside right?
If your support is inside your model and you can not access it with a pair of pliers you have made a high quality maraca![;)](//content.invisioncic.com/ultimake/emoticons/5a33abe00be82_1f609copy.png)
