80/20 Ultimaker Cabinet
mendells
Posted · 80/20 Ultimaker Cabinet
Just thought I would share the cabinet we made at work for our Ultimakers. The cabinet can store up to 6 Ultimaker 2s (less if you have the extended versions), has room for 64 boxes of filament (we use ColorFabb mostly), sealed and temperature controlled, and has pull out shelves for easy access.
It wasn't cheap and its very heavy but its a lot nicer and cleaner than the wire rack we were using before.
  • Like 6
I believe it was around $3500 for everything, so not cheap but its what we wanted. There are some things I would want to change if we made another one but overall I am very happy with it.
    • 1 year later...
    That is really awesome :)
    Wow awesome!! I was also planning something similar for our company, maybe a smaller version, can you share the CADs?
    Very nice. However, I think you got ripped on the bottom middle one. Might wanna check with your reseller... :p
    :'D
