This argument yet again. you may want to search this topic on the forum and be prepared to read pages and pages.
Short answer, This wont happen.
There has been plug-ins to do this on pre CURA 2.xx
It should not cause any delays by changing settings as it will just re-slice but you dont need to wait for it to finish before changing another setting. Just keep changing all your settings.
If you do get lag and cant continue to adjust settings then there is an issue that needs reporting for the software team to investigate.
It lags because it draws resources from the computer .. it's a rather simple thing .. and is also the #1 complaint about Cura. there is really no reason I could possibly think of not to implement it. Obviously if thee is such a heavy repeated complaint/discussion here about it you'd think they'd think about actually listening to the people and what they want/need.
Labern 775
