The more information you provide the more help this community can provide. What system, material, extruder temp, bed temp, etc.
yellowshark 153
"... That large piece went from one entire quarter peeling up by the 4th layer, to now I can't lay a single bead to start because the line rolls itself up, or if it does stick in an area initially it is pulled off line by the continued bead....
Yup @gr5 is absolutely right. Your lines of filament need to be "flat" not "round". If you find your walls on the 1st layer are sticking well but the infill is not sticking then you have gone to far, back it off a little - .050mm can make a huge difference
gr5 2,230
Almost certainly your nozzle and bed are too far abpart. I don't care what the calibration routine is - you are ending up with the bed and nozzle too far apart on the bottom layer. What kind of printer is this?
