Print to stick
BWilt
Posted · Print to stick
I just got the Ultimaker 3 I today and I have been setting it up. I was wondering what the best method to get a build to stick to the plate is. Can I just print right on the glass or do I need to use a glue stick or some painters tape? I will start using Pla but do different materials stick best to different beds?
Thanks!
    There are many alternatives. Hairspray, PVA glues/slurry/gluestick, and some plastics don't need a sticky layer if the glass is cleaned and temped correctly.
    It's a lot of reading and asking LOL
    PVA gluestick is good for PLA & the PVA filament. Just spread on your plate & then spread it around with a wet paper towel. & dry with the heated bed.
    ABS is a little trickier you can use some ABS slurry ( ABS partially dissolved in some acetone ).
    Or some Kapton tape. Which is much cleaner than the slurry & less smelly.
    Just stick the Kapton to your bed & rough up with some 400 grit wet n dry ( clean afterwards ) it's really good & it's what I've found most effective. & can be reused over and over if you remove your print carefully, & when you want to print on glass again flip the glass plate over & leave the Kapton in place.
    Which seems to not cause any problems. Luckily I had another plate given me so I now swap them back n forth depending on what I'm printing.
    But there's a Myriad of different techniques to get your print to stick & there's more than a few videos on the subject ...finding one you like is another story altogether : D
    ....But there's a Myriad of different techniques to get your print to stick & there's more than a few videos on the subject ...finding one you like is another story altogether : D
    I completely agree as each scenario you explore will be dependent on a few factors such as brand used and environmental conditions.
    It will be a completely personal choice requiring the exploration mentioned here.
