I thought active leveling was just the auto-level part it does before a print? So it actually adjusts the build plate height during the print?! Wow! Awesome! Thanks for the clarification.
fbrc8-erin 316
Glad I could help. :-)
The active leveling has 2 parts--it does do the leveling at the start of the print, which is useful, particularly if you're swapping between multiple pieces of glass, but it also corrects during the building. The first 10mm are corrections for the leveling/plate, and the second 10mm phase out those corrections so everything is totally level by the time the print is 20mm high.
1
- 7 months later...
I guess thats what this noise is?
Specially at the start of the video the Y angle smooth rod seems to wooble. I would make a closer video to the shaft entrance on the printhead (slowmotion iPhone can show wonders) and if it woobles I would ask to the reseller to fix that.
I will try to get another video when it gets to the top layer. Its not doing it in the middle section where there is no solid layer.
kmanstudios 1,120
I did not know it operated on the buildplate during the printing process as well. I did adopt the active leveling at the beginning of the print since moving most prints to the Cura Connect. I used to do it manually, but it does make a difference when changing plates.Glad I could help. :-)
But, thanks for the additional info.
fbrc8-erin 316
It sounds like it's your active leveling, which is a totally normal sound to hear on the UM3E, but definitely a bit unnerving if you're used to printing on a UM2. I keep meaning to make a video of noise for reference and comparison between the two machines.
The active leveling process makes tiny corrections as your printhead moves across the bed, for the first 20mm of printing height. This is caused by the Z-motor making lots of small movements.
