Yes i measured the filament diameter, it's 2.85 to 2.9. I've uploaded new photos. There are blobs but very small. Mainly i get an rough surface that feels like touching a fine sand paper.
I still have my doubts, is it under-extrusion? or over-extrusion?
I use Flow100% Retraction 6.5mm at default speed. Firmware Tinkergnome 17.02.1
zoev89 73
Did you measure your filament diameter? Could there be a significant difference.
It is difficult to judge from the photo what the effect is. For under extrusion usually you see small gaps between the lines but to me it more looks like over extrusion because I can't see the small gaps but I think I see blobs of excess material.
