cloakfiend 994
I used to use rafts back in the day, but I only use PLA from Colorfabb now, and print with a skirt on prittstik power glue and no infill or support, to minimize waste, but have kind of been away from the printer for a while so am wandering why its doing this, but i saw it on a few of my letter prints too. Ill give the raft a go, i never really had trouble taking it of the raft, but only did it with ABS which i dont use anymore.
I havent applied glue or re-leveled in about 6-8 months but it does this even with brim selected and doubt the other stuff matters....This model is just for fun but was hoping to have it done in a day or so but it doesnt look like it.
I want to print without heat on the bed, neokto had a nice technique i must investigate and finally try somthing new out.
I feel its the heat of the bed combined with the nozzle temp, bummer.
kmanstudios 1,120
Type of material? What are you using for strickum to da buildplate?
I ask because I have been reticent to use rafts but have found they can be removed if taken off while still warm to hot.
But, I am speaking specifically about PC and CPE+ as I have not had this be an issue with PLA or other things so have not tried it with other materials. But, does work like a charm with the filaments I mentioned.
