Just very important. Don't overscrew the board that goes behind the cores, or it will make a contact error. As a general rule, don't overscrew anything.
Thenonly semi complex part is the plastic that has the little spring on top. Try not to loose it since is quite thin and jumps a lot
ultiarjan 1,215
I don't think an assembly manual is publicly available. @sandervg any change you can share something?
I think the mechanical parts a pretty self explanatory, screw the metal bottom plate to the top plastic part first, so you can drop it into the bottom plastic part.
Put some (green) magnalube on the small mechanical switch parts, then the little metal bush goes on top, the spring goes on top of that.
The thing I'm not sure about is the order of the connectors to the electronics board, does the board have labels on it? maybe someone else can pitch in...
Then put the hole thing together with the bearings in it, and screw together with the 4 long screws.
