Hey, I just finished printing 2 P47's from 3d labs using Cura 2.6. I can confirm their supplied settings will work with a few speed and retract settings.
What I did first, and it helped a lot, was I nailed the "First Layer Height".
I printed a 1 line skirt, stopped the print, measured it, and adjusted a G92 Z in my printer config to establish a perfect First Layer Height.
Next, I printed a one walled test box, about 50mm square, maybe 10mm high. Measured the wall thickness and adjusted my extruder percentage. Currently I am actually at 89% even though I calibrated my extruder steps perfectly. Not sure why its so low, but it produces awesome results.
Once this is done, I printed my main parts, Fuselage and Ailerons using,
67C Built Plate, 220C Print Temp First Layer, 210C everything else.
.15 - .25mm Layer Height (I am currently printing at .15, but had great results at .25 too)
.4mm Wall Thickness,
0% Infill,
No Top or Bottom layers.
Print Speed ("Wall Speed") around 30mm/s,
Travel Speed - 200mm/s
Initial Layer Speed - 17mm/s
Now looking at your pick, I am guessing you have an oozing problem from possible poor retract, or moving to slow from point to point to point. This is why I jacked my travel up to 200mm/s.
I also have a direct drive extruder, so if yo got a bowden style, you may have to greatly increase your retract settings, but for reference if you want to try, here are mine:
Enable Retraction -Yes,
Retract Distance - .8mm
Retraction Speed - 25mm/s
Retraction Extra Prime Amount - .16mm^3
Minimum Retraction Travel - .8mm
I will get back to Retraction Extra Prime in a sec.
Now I was getting strange issues like you had, and I was also getting blotches all over the print, so I changed my Z seam to be aligned into the same location on the model. When I found when I did this, was every time I went to start a new layer, my nozzle would ooze a tad and when it went to start the next layer, I had a bit of an under extrusion right at the start. Very hard to see this if the Z seam is scattered all over the place randomly. Once I aligned the seam, I could clearly see the under extrusion, and so I adjusted the "Extra Prime" amount. I had to play with it a bit, but I got a good value that works pretty well.
Good luck, enjoy. This was a blast trying to print these models. I wasted a whole spool of filament trying to dial it in before I printed my real one.
gr5 2,196
Did you see the problem in layer view? Could it just be skipping that section? Thin walls sometimes dont' get printed. Try setting nozzle width/line width to 0.2 just to see what happens in layer view. You can certainly fudge it a bit - .3 line width with a .4mm nozzle will work. In cura 15.X it's critical to make the shell width a multiple of the nozzle width. If not it will ignore the nozzle width.
