I am not sure, but can't you do without spring? And replace it with a piece of metal of fixed length and suitable design? So that you can still finely adjust the position of the pressure wheel, to get the desired bite-depth of the teeth into the filament?
I have always wondered why there are springs in the feeders of almost all printer brands? Yes of course, officially they are needed to push the filament against the knurled feeder wheel, so it gets a good grip. But does it?
If the spring tension is too high, it flattens the filament into a plate, instead of a round. Then the filament gets stuck in the bowden tube, or nozzle, or at least causes high friction. If spring tension is too low, it causes slipping, or the feeder-teeth jumping out of the filament, instead of biting. So we are supposed to find the nice spot in-between those extremes. But is there always an optimal spot in-between?
If the feeder would have fixed setting-screws, so we can finely adjust how deep the teeth bite into the filament, but without spring, then I guess that should reduce both effects: it should stop flattening the filament, as soon as the teeth have bitten into the filament for the desired depth (because at that moment there is no more pressure)? And it makes it more difficult for the teeth to jump out of their bite-pits (as there is no soft spring that can give way)?
Or am I overlooking something?
Maybe in Robert's feeder this would be easier to test than in the original feeders?
IRobertI 516
Unsure of the spring. Looking at the BOM for the 2+, this is mentioned "DIN 17.224 material nr. 1.4310", does that help?
To prevent the spring from flying away (which hasn't happened to me yet even though I've opened a fair share of feeders), set the tension to the minimum setting before opening the feeder. It will make re-assembly easier as well.
