I will try that tomorrow with the .4 BB.
I swap it for a BB .8 but Cura does not switch it to BB .8 even though the UM3 recognizes it. But, I will try the .4 BB again tomorrow.
thanks.
thanks.
I tried the atomic pull. But, it did not appear to have additional filament in the printcore. I tried a few pulls.
How's the environment?
PVA gets soft from higher temperatures and higher humidities. Use it below 28degC, and below 55%.
If ambient humidity is higher, store the PVA in a dry place, with desiccant. When using it for long prints (>24h), craft some drybox to print from.
I'm within those numbers for temperature and humidity. But, I used this as soon as I unwrapped it and that's how I got these results. So, the PVA was not laying around. After, the bed leveling and setup, I unwrapped it at that point. So, there was no time for it to develop any issue like that with such short time frame.
Like I mentioned before, I would have tried my BB/AA .8 but, Cura doesn't let me select the BB/AA .8 when switched out from a .4. (That's another case I have open).
hiya,
this might be your problem.
I had this problem and it was the hot pull that worked for me.
https://ultimaker.com/en/community/51107-ultimaker-3-bb-core-problem-solved-here-is-how
when you check the filament length all the way to the feeder, do you see a massive gouge where the gear has eaten into the filament?
this is my working solution
kmanstudios 1,120
Just to be thorough, have you tried to do a set of hot pulls and atomic pulls? I am thinking something may have gotten stuck or burned inside.
When I first got my UM3E, it did not want to extrude until I did a cleaning. And, the BB core requires a bit more love and care than the AA core because of the nature of the PVA.
