What version did work? If a normal re-install doesn't work than a 'clean' re-install is a good way to go.
You could try to look in the log-files $User/AppData/Roaming/cura/2.7/ if there are error's
Roaming/cura/2.7 was blank... the only folder in there was plugins and that was empty.
This is what I found in APPDATA/Local/Cura/stderr
Fatal Python error: Segmentation fault
Current thread 0x0000027c
(most recent call first):
File "D:\2.7\build\inst\lib\python3.5\site-packages\UM\View\GL\OpenGLContext.py",
line 29 in setContext
line 104 in detectBestOpenGLVersion
File "D:\2.7\build\inst\lib\python3.5\site-packages\UM\Qt\QtApplication.py",
line 71 in __init__
File "D:\2.7\build\inst\lib\python3.5\site-packages\cura\CuraApplication.py",
line 205 in __init__
File "D:\2.7\build\inst\lib\python3.5\site-packages\UM\Application.py",
line 316 in getInstance
File "D:\2.7\build\inst\bin\cura_app.py", line 72 in
File "Console.py",
line 24 in
File "",
line 634 in _load_backward_compatible
File "",
line 664 in _load_unlocked
File "",
line 958 in _find_and_load_unlocked
File "",
line 969 in _find_and_load
File "__startup__.py",
line 12 in
File "",
File "",
File "",
File "",
Msuurmond 28
