Circles are not fully round
ayouden
Posted (edited) · Circles are not fully round
Hello all,
I know this seems to be a common fault with Ultimaker Original machines, but I seem to have tried all remedies suggested and it still refuses to work!
I have:
Put Belt tensioners on Long belts
Tightened the short belts by pushing down the motor
Tightened the cross axis rod block (Thinner rods which mount to the print head)
Made sure hot end doesn't wobble/move freely
Checked extrusion rates
Tightened all the pulleys to the rods
Made sure the cross rods are square
The errors seem to be happening at 45* from the X and Y, so it leads me to think it's a belt (slack) issue, but with tightening every single belt, I'm at a loss!
I hope someone might have some suggestions?
Regards,
Alex
Bottom right circle seems to show the defect clearly as it has gaps in the walls at half one and half seven. It should be solid like the other quarters.
    Posted · Circles are not fully round
    Hi
    I don`t have a Ultimaker, but had the same exact problem on my own printer.
    You have a perpendicular, or parallel, axle (x,y,z) problem, they are not at exact 90 degree, or parallel, from each other.
    Regards
    While knowing you said you tensioned the short belts, I am still inclined to think the problem lies with your short belts. Do you have a photo of some reference on how tight they are? Perhaps pushing against it with your finger?
    And can you move your printhead around with just 1 finger pushing against your print head? How freely can it move / how much resistance do you feel?
    Thanks!
    Hi SandervG,
    I have tightened the short belts very tightly indeed.
    There is hardly any flex in them at all.
    There seems to be moderate resistance, but this feels like it's coming from the belt tension.
    Could they be too tight?
    I have also double checked my alignment, still all good!
    Regards,
    Alex
    Could be a loose pulley on a motor/shaft!
    I put marks on mine with a permanent marker, a stripe that goes from shaft to the pulley. A quick look will show if anything moved.
    // Per.
    Hello
    I have simmelair problems
    Wonderd if and how you solved the problem
    Wr Henl
        • 56 replies
        • 29 replies
