PP won't stick
flyntm
Posted (edited) · PP won't stick
I use painters tape and spray Isophrol alcohol to remove the sheen,
then I put down a good layer of stick glue on the tape where the print goes and spread with a towel so it is not clumpy.
I also slow the speed down to 90% until it gets started then back to 100%.
Make sure your bed is level.
Also if you can use a larger print head it will print easier and faster, all I use is the .6 &
.8
    • 1 month later...
    Posted · PP won't stick
    I also had some challenges printing with PP. Overall, still don't like printing with PP but at least I got it stick to the build plate.
    I tried a couple of things but got best results with using adhesive spray (see picture), the one I always use, even when printing PLA. So I use the spray, have build plate adhesion and a bed temperature of 100 degrees. It does the trick for me.
