This shouldn't happen for the 3.0 release anymore.
Thanks guys, but the next question arises: "When can we expect Cura 3.0?", and: "Does it have a new material model for custom material specification?"
Edit: Just found out that it is in two weeks time!
It does not have a new material model.
That is a pity, but at least the leak is plugged!
- 6 months later...
Just updated to Cura 3.3.1 At the end of my 9 hour print I had memory problem with my Windows 7 box.
Checking Cura memory usage I found Cura was increasing working memory by 160 kb/minute.
At that time working memory was 96 Mb and virtual was 312 Mb
Is this normal ? Haven't really checked on Cura memory data before since I saw no problem.
Dim3nsioneer 557
You mean using a few GB for a simple small STL is not normal?
The situation should get better in 6 days.
