Sry I meant Sprialize and yes I'm talking about the 1cm spiral that shouldnt be there
I dont want to use supports, maybe its the acceleration, but every other print (big ones) turned out great. btw. I'm using the CR10.
I don't know the CR10 but have you tried using printrun/pronterface to control it? I assume your printer has a USB?
Software is free here:
http://koti.kapsi.fi/~kliment/printrun/
When you connect to the printer, if it is Marlin or similar it should list out all the settings including the acceleration. Make a note of it and then cut the acceleration down severely - maybe by 5X. Here is the gcode you can type into printrun to set acceleration (again assuming marlin - when you connect with printrun it should tell you if it is running sprinter or marlin or something else)
gcodes explained here for most firmwares which covers 99% of printers out there:
M204 S300 ; 300mm/sec/sec - very slow - UM uses 5000, most printers around 1000
Print with this and you will hear the difference. Just insert the command early in your job or do:
M500
To save this setting permanently (otherwise it gets reset to defaults on power cycle).
This looks a bit like when you manually extrude silicone paste in a circle: it sags, and it pulls the previous layers sideways due to its own unstability and flexibility.
Could that be here too? Maybe: temperature too high, walls to thin, material too flexible (for the size of the object), or some sort of mechanical wobble in the model due to inertia or resonance?
If I had to print it, I would print it as slow and cool as possible. With thick walls. And with a layer height of only 0.1mm: a thicker layer height needs more time to cool, and might easier be pulled sideways than a thinner layer, I think. But this is a guess.
gr5 1,504
Okay this is confusing because "vase mode" in cura used to be called "spiralize" but you are talking about that large (1cm?) spiral I think.
I've never seen that. Could it be some vibration - a harmonic vibration from your bed moving back and forth? Try lowering the speed or maybe just the acceleration.
Probably just the acceleration - I don't know what kind of printer that is but it probably has Marlin which allows you to specify the acceleration with a gcode. Look at what it is currently and cut the acceleration by a factor of 4X. It shouldn't slow down the print too much.
Another fix might be to add interior supports to connect one side of the print to the other occasionally that are later removed. Or exterior. But you would have to disable vase mode.
