What OS do you use? If you use Windows, you could try the following:
Replace C:\Program Files\Cura 3.0\resources\shaders\grid.shader with this file:
When adding the first printer, it is the first time the buildplate is drawn. The shader that should draw the grid lines on the buildplate is broken on older GPUs. A fix was made, though it was not included in the 3.0 release. Replacing the grid.shader applies that fix to your local installation.
1
Bud1 0
I have the same problem too. no response from support.
