Yes, like I said I have played with this values already, I have used 400 and even 100 but it doesnt make any difference.
I wonder if the ulticode flavour has a play on it? As a standard it is configured for 1/8 microsteps for the Z axis, is there anyway I can change it on Cura?
gr5 2,243
Can't you just change it to 80,80,400,282? That should fix it.
The Z axis has a jumper roughly in the center of the board that can switch the Z between 8 microsteps per step or 16 microsteps/step. By default the jumper is off and that makes for 200 steps/mm.
But you are using the second extruder stepper which is always 16 microsteps / step. So you need to set the steps/mm to 400 instead of 200. Easy. You can do this with gcode commands if you don't want to rebuild marlin.
