I may have had this exact same problem - not sure. Is this a dual extruder print? I had it with the default profile for 0.8mm in cura.
One of the problems is that the default profile does a retraction on layer change. wtf? I don't know why. None of the other profiles do that. It's a bug. I reported it but it apparently was ignored. So check that - something like "retract on layer change".
Also there were speed changes and flow changes that were the major issue. I changed my settings so that line width was ALWAYS 0.8 (changing line width on infill can lower the pressure in the head and it takes time to recover - your 10mm issue). This was the larger issue.
So set all lines widths to be the same (0.8mm) and set all SPEEDS to be the same (all printing speeds - travel speeds should be >=150mm/sec).
gr5 2,024
