Ah, thank you so much. But it sounds a bit strange, up to now the line width was more or less synonymous with flow? In the mean time I found that the nozzle diameter can be set in the preferences-printers, then machine settings. So that's settled!
Yet there seems to be a problem that the feeder motor is running far too fast. I reduce the flow to 80 percent and it still seems too high. Hm. I will send an e-mail to the previous owner...
Can I find somewhere what should be the exact type of the moter? Ours reads: 17H06482-01N If I read well... the first 0 might be D or O
thanks again,
Lies
PS, I will soon dive into the new Cura...
gr5 2,196
In cura 2.* and cura 3.* you instead set the "line width". There is a big learning curve for cura 3.*. You might want to stick with cura 15.* but there are a few pretty amazing features in the latest cura once you learn everything.
