I have seen it during the cura connect early beta... But have not had it recently.
can you maybe provide some logs? You can get those via the dump logs to USB option in the maintenance menu.
Did you turn off the printer shortly after confirming the buildplate was cleared?
If you do/did that, it can explain the behavior you're seeing.
There will always be a chance of unintended consequences when you turn a computer of just after doing something that should be saved, this is no different. And in our case unfortunately off is just that, imediate, like pulling a plug.
Edited by GuestI also experienced the bug(printing the last job even when not selected) a few times in the stable 4.0 release.
@robinmdh How long do you recommend to wait? What about a way to turn of the machine by selecting shutdown on the lcd?
1
@cjs, A minute or 2 should suffice.
There currently is turn off menu option and with the current hardware it is dubious. (yes, the software can turn off, but then everything is still powered on, the user must then still use the switch at the back; why would you want to do both?)
can you confirm then that this happens after clearing a buildplate clean message, followed by a power cycle (turning something on and off, not related to bicycles of any kind:P)
We were thinking about a status indicator, telling you not to switch the machine off, but preliminary work seems to indicate this will not work with our file system.
Edited by GuestOh, right and I forgot there is a bug that when you don't clear the "print finished, clean buildplate" message before a reboot it will come back as a "print FAILED, clean buildplate" message and after clicking OK on that, the print will indeed be reprinted. :(
Edited by Guest@cjs, A minute or 2 should suffice.
You wouldn't want to do both and therefore people would probably only use the switch. (Just remembered that this was some advice in the raspberry pi documentation at some point I think)
What about a standby(motors and oled display turned off until click wheel input) mode? To prevent oled burn in. Turning off the screen would also be nice while printing after x amount of time as I know UM2+ suffer from burn in. Or some kind of pixel shift to prevent burn in (like samsung does on their smartphones).
I do like the idea of an indicator. Maybe a static indicator, which gets displayed for a certain time (1 minute) after input ?
Yes I can confirm that this happened to me a couple of times with firmware 4.0. I think I also experienced it after a power cycle but not as often as it isn't the normal use case. Haven't printed that much with 4.1 and therefore don't know if it was fixed.
After confirming this message as well as the one after an aborted print.
Oh :( Can we expect an update withe the fix soonish?
kmanstudios 1,120
I had something like that happen to me yesterday. It is covered in this thread.
Not sure if it is the same thing or not, but it sure sounded familiar.
kmanstudios 1,120
I have never seen this issue. Did it start immediately or did you notice shortly after? Are you using Cura Connect to print or other method?
