The printer is an UMO as stated in the profile.
I don't think there is a problem with the Power Supply because the Ulticontroller does not flickker or flashes before it happens. The Heated Bed is an Original Ultmaker Heated Bed upgrade from 2016.
It only happens when the Temp is beneath 60° from the start or during the print when changing the Bed Temp after the first layer. Then when the Bed has cooled down to the Temp that is demanded, the printer shutts off and does a reboot.
When the Temp is set to 60°, the printer prints for hours without an issue.
gr5 1,516
The resistance of the bed increases with higher temperature which means it is lower wattage the hotter it gets. When the print starts it suddenly draws much more power for the 4 steppers.
I'm guessing your power supply just can't quite handle the nozzle, bed, and steppers all at the same time. When the bed is a bit warmer it draws less current so everything can be on at the same time for a few seconds without losing power briefly.
The brick power supply has this feature where it shuts off very briefly but then it's too late and the printer reboots.
The um3 has newer firmware that is more aware of the varying wattage of the bed and does better power management. But his is a UMO?
In Configuration.h I think you can limit the power to the bed. You can set it to 0 through 255 where 255 is the highest power. This feature does not work in "bang bang" mode which I think is default. I strongly do not recommend bang-bang mode as it causes all kinds of other issues also.
Maybe you just need a more powerful power supply?
