Posted · Ultimaker Original - Top face not filling in correctly
Hi Community,
I was hoping you could help me. I'm currently trying to print some Christmas ornaments but keep getting this on the top face. Any recommendations on what I need to do. This was a fine print using 2.85mm PLA. Any additional recommendations would also be welcome. Thanks.
    22 hours ago, gr5 said:
    Is this Cura 3.X?  I recommend you go back to an older version of Cura - certainly 2.7 is safe.  There is much discussion of this here:
    https://github.com/Ultimaker/Cura/issues/2665#issuecomment-349396443
    Thanks for that gr5. Will give it a go and see what happens.
    1
     Hi gr5. unfortunately, I'm still getting the same result. I've changed the settings and the design but have had no improvement. Any other ideas?
    Not even slight improvement?
    Well I see underextrusion on the top layer before it prints the name.  I would try to fix that by printing a bit slower and maybe a bit hotter.  Try 10C hotter and at 70% speed.
    Actually I would make some smaller test piece that does this - maybe print just the R.  And play with stuff in the TUNE menu.  Actually it looks like you have some pillowing which is fixed by more fan (you want 100% fan for PLA) and more "top layers".  At least 1mm top/bottom thickness.  It takes quite a few layers for things to recover over infill.  More on pillowing here:
    http://support.3dverkstan.se/article/23-a-visual-ultimaker-troubleshooting-guide
