Yes, ideally the screws should be aligned in such a way that they are both visible at the same time. It's very easy to "mess up" during assembly though. The way you handled it sounds fine to me.
The ferrite cores aren't strictly necessary. Like gr5 said, they're there for certifications more than anything. The number of ferrite cores and where they're placed have changed a couple of times over the years.
The beep you're hearing. Could it be retractions? The new feeder is slightly louder and the motor spins at a different speed so the change in pitch might be what you're reacting to compared to the old one. If that's not it, post a video/sound clip, otherwise it's very hard to figure out what it is.
gr5 2,331
This. This is your answer. But I'm sure you did fine.
I think the ferrite cores are to reduce electromagnetic radiation for other things near the printer. For example without the ferrite cores you might have trouble getting wifi or data on your phone. Maybe. Or more likely AM radio signals might suck within 2 feet of the printer. I doubt the cores make the printer work any better. I could be wrong - but I think they are just so you can pass FCC regulations. FCC doesn't like you being a little radio station.
