Thanks for the quick response.
Oh dear, not the info I was hoping for.
Back to using multiple slicers then.
Hope that the Cura developers will fix that after all these years.
Try setting "Line Width" slightly lower than 0.4. I set it at 0.38 and it sliced fine.
Thank you so much, clicking on settings and searching "Thin" allowed me to tick the "Print thin walls" option and now its slicing perfectly.
Thank you once again, great community.
Your wall line width must be the same width as the thin wall you need to print and print thin walls must be on.
On 12/29/2017 at 12:33 AM, ultiarjan said:
Thanks heaps. Solved my similar problem with an ice cube tray!
yellowshark 153
Your thin walls are too thin for Cura to slice; you need to make them thicker
