Thanks for the reply. I Initially thought it might have been that so I pushed it in quite hard. I've had two of these Hardcores for a few months now and the other Hardcore seems to be going OK after a firm push-in but one of them is still on the brink of throwing the error. How do I know this? The orange spikes in the graph below is the Hardcore reporting 700C for an instant. Not enough to throw max temp but enough to show the material compatibility warning on the display just like when a new printcore or material is inserted.
Eventually I know this will turn into max temp errors after a while.
My silicone pad is on OK I also print with 0.8 and 0.3 and sometimes with PETG it can get pushed around but I always make sure to re-seat it.
I have tried desoldering the temp sensor on the back of the print core removing the connectors and resoldering the wires back on. While I had it disconnected I tested the sensor by wiggling dropping and flicking it while hooked up to a multimeter. Granted this probably isn't the best way to test I didn't have an oscilloscope handy at the time. On the weekend I'm going to try a higher tension spring and maybe a shim behind the print core PCB to ensure the connections stay firm. If it persists after that I'll lean more towards suspecting the PT100.
gr5 2,229
Sorry I didn't see this until now. The first thing to make sure - push harder on the clear part until you hear/feel it snap in. You don't have to do this with the UM cores but the hardcores need a little extra push.
Are you printing with the silicone rubber installed in the print head? I was printing with a 0.8mm nozzle and 0.3mm layers and the silicone pad was missing and that got enough wind inside to make it so the core couldn't keep the nozzle hot (now that I think of it, that was a UM core, not a hardcore - still - the silicone rubber helps).
It could just be a bad/intermittent temp sensor wire (or heater wire). If it's the temp sensor wire you will also see the temp bouncing around. If it's the heater wire it will cool a bit unexplicably and get heater errors. Heater error and it's *usually* the heater. Temp sensor error and it's always the temp sensor connection/wiring. If problems persist you should ask the seller for a new hardcore.
