On 22.1.2018 at 8:15 PM, gr5 said:However if you want a 3dsolex core to show up as "AA 1.0" or "HC 1.0" and want to create profiles to auto load your settings - I can help you with that. I already have software that does most of the work to do that. You could just make a small change and it will create all the profiles for an alternate UM3 core in seconds.
As I am already considering the 3DSolex cores - if and when I finally get the UM3e - I'd be interested in learning more about the sw you mentioned.
Is that some self-made tool?
gr5 1,872
It's my "neighbor", Kevin! Hi there!
I don't think Cura does anything with the "outer diameter" yet. not sure.
The old cura (versions 14.X and 15.X) indeed had a nozzle diameter but it was a confusing feature because if you told cura you had a 0.45mm nozzle but set the shell width to 0.8mm it would ignore your 0.45mm and set it's internal line width to 0.4mm. At least now you can set the line width directly. I feel that is an improvement. I had to tell people thousands of times on the forum to set the shell width to an integral of the nozzle width or cura would override your settings to suit it's needs.
So really the only thing you need to set is all the various "line width" settings in cura 2.X and 3.X. No need to create your own custom profile.
kevin-osborn 9
Cool. I was just pleased to get such fast print times. A part that used to take 30 min at .15mm layers now takes 8 min with .5mm layers and 1mm lines.
As you said, I had to make sure the walls in my design were a multiple of the nozzle width (plus a little for some reason when the multiple was 1).
When I set the walls to be exactly 1mm in my design, I got gaps in the perimeter (in layer view, hence actual gaps in code) especially on circular features.
Probably some sort of roundoff error. made the shell width 1.1mm and all is well. (though it may be going over some lines twice.)
