fbrc8-erin 235
I haven't seen reliability issues with the newer bricks and the UM2s. Are you having any issues with the power if you heat the bed but don't run the printhead? It's possible there could be an issue with the heated bed plate rather than the power supply.
gr5 1,512
This is a common problem with the UM2 and the newer power supplies that ship with the UM2 and the UM3. The UM3 actually has special code to keep the main bed heater from drawing too much power when the nozzles are both drawing power.
One fix is to just contact your reseller and have them ship you another power brick. Don't ship back your current one until you get the new one.
Another fix is to buy the "GS" model and not the "GST" power brick. Below are the 2 part numbers. This will cost more but you will have a more reliable power supply (GS doesn't meet efficiency requirements for certain countries so UM had to switch to GST). But the GS bricks cost about $90 each. Anyway that is the route I went. It has a much larger "headroom" aka "power margin".
GST220A24-R7B
GS220A24-R7B
A workaround while you are waiting for a replacement supply is to print on blue tape. Make sure to re-level and make sure to clean the blue painters tape with isopropyl alcohol first.
Printing at a lower bed temperature is NOT a good workaround because the bed actually can draw more power at the lower temps (the resistance increases with temperature).
Luvbread 0
Hey!
Thanks for the answer.
I have tought about a PSU Failure aswell at first, and thanks to your answer im sure about that now. I actually own a GS220A24 power brick already, would it still be recommended to switch over to the GST?
