Help with modifying fanducts
baasb
Posted · Help with modifying fanducts
Hello,
I'd like to ask someone to help me with modifying two STL files with fanducts. I really love the design of these fanducts which are designed by Blecheimer.
New Fan Ducts
But, they are designed for the V1 nozzle. And although they worked great initially, after a while there were some problems:
- The right nozzle blows a little bit too high, right on the nozzle and thus cooling it.
- The ducts are clamped on the wooden block and the aluminium plate. The heat of the aluminium
plate deforms the duct and after a while it comes loose.
- The upper 'clamps' are very thin and due to the vibrations, they're getting very weak.
- Because of this deforming and weakening of the clamps, the ducts start to come loose and
touch the bed and printed object. The left fanduct became so loose that because of the vibrations
it touched the heatingblock and melted to it.
- With the fans fixed on the duct, the whole unit is a little bit too high and so touching the wooden
XY blocks on the left and right. I had to scrape away the black casing of the fan to make them fit
under the blocks so the head could move freely.
As I am not very skilled with 3D modelling I would like to ask is somebody can fix the fanducts so they fit the V2 nozzle. That would mean:
- The right fanduct has to blow under the nozzle, so tilted some degrees counter clockwise.
- Decreasing the total height of the duct so that it is further away from the bed/print (now it's 0.2
mm higher than the nozzletip).
- Strenghtening the upper clamp so that it can handle the vibrations better.
The files are below:
Left Fan Duct
Right Fan Duct
I'm willing to testprint the modified nozzles to see if they fit better!
    Sorry for my late reply. I am a little bit busy at the moment...
    I re-worked the right fan duct. Now it aims a little lower and has to be bolted onto the hot end. Use two M3 nuts and assemble the new fan duct to the very long bolts at the hot end.
    New Right Fan Duct
    I have not printed and tested this fan duct yet. Do not know it it fits - so you might give it a try and see if it works for you.
    I hope I can re-model the left fan duct during the next weekend.
    Wow thanks man! I gave up all hope because no one replied :wink:
    I'm going to print this fanduct and see how the results are. I think I'll add a rectangle to connect the two suspension pieces to make it thicker. Because this piece gets easily fatigued due to the vibrations. I can do that myself in TinkerCad ;)
    It looks like the exit area is quite small compared to the intake area of the fan. I remember seeing discussions in the past that these sort of designs didn't work well because the standard 40mm square CPU cooler fans aren't capable of sustaining the necessary pressure to handle much reduction in output area. Does it work ok, in practice for you?
    Do you have any results showing the improved print quality that these designs makes possible?
    I do not know if 40mm fans cannot handle the pressure as I am using the original 50mm fans. For me the original fan size is the perfect match for my fan duct design.
    I am working with these ducts for half a year now without any problems. And I am quite pleased with the results:
    This is an early model to test overhangs.
    click for larger image
    My compressor wheel @ 0.05mm layer height
    Compressor wheels @ 0.1mm layer height
    click for a larger image
    The UM-Robot - the hands could be better
    Certainly looks like you're getting some nice results!
    So I tried printing this off for my ultimaker. I'm not really sure what the difference is, I think mines a revision 3 ultimaker so it didn't quite fit properly.
    IMG 00000836
    It made contact with the hot end when fully pushed in. And prevented the print head from moving to zero because the fan hit the slider block, and then the screw on the slider block causes lots of friction on the part that mounts to the long screw.
    IMG 00000835
    I managed to use it kinda hanging on a thread.. Functionally it seems pretty good!
    So I redesigned one based on these dimensions and the problems I encountered:
    It's a bit lighter. (11g vs 16g)
    The duct is more direct, nozzel a little smaller. (wasn't intentional.. just happened that way) and a bit thinner everywhere.. but it pretty much fits perfectly on mine now without hitting the fan, screws or hot end.
    You mentioned you wanted it a bit lower, this is about 0.8cm lower, and the fan is angled by another 5-10 degrees. Feel free to try if it helps. Here are some pics.
    IMG 00000838
    IMG 00000839
    IMG 00000840
    blecheimer's design still looks cooler though I think.. Mine could use a bit more polygons bubblyness and fillets.. but alas, I'm using artist software which makes all that stuff difficult.
    Download here:
    http://www.thingiverse.com/thing:109850
    Nice piece of work, Valcrow! :)
    I was re-thinking my design and made a rough sketch of the V2 hotend. This allowed me to adjust the position and the air flow of the fan ducts:
    Right Fan Duct for V2 HotEnd
    Left Fan Duct for V2 HotEnd
    As I am still not using the new hotend I do not kown if this new design really works. Feel free to download the V2 fan ducts and give it a try.
    Sweet! I can try that one when mine melts.. I think mines a bit too thin seems a tad flimsy.
    I imported your v2 to compare, I think it'll fix pretty much all those issues I had earlier, except the fan might still hit the sliderblock.
    Awesome design btw. I don't know if I could have printed mine properly without using yours ironically. Hope you don't mind me bastardizing your design. :p
    ...except the fan might still hit the sliderblock
    Yes, it will hit the slider. I have just cut the fan casing a little bit and now it fits nice and easy.
    I'd like to see modification of my design. Just take it and improve it. :)
    Oh yes, I totally forgot that that was one of the main reasons I'd like to modify the ducts. But I cut of som of the housing of the fans to that they would fit under the blocks... let's just say that it works ;-)
    Using those fans a few day's now, working perfectly !
    Using it with http://www.thingiverse.com/thing:45236, so the fan's don't toch the bushing blocks.
    Thank you for sharing !
    IMG 0477
    IMG 0476
    IMG 0478
    Hi Blecheimer!
    I'm currently trying to design a sheet metal version for 4pc. of 25x25mm fans (2each side) similar to UM2 but I have seriouse problems in design.
    I like your design and would like to give it a try but also with those small 25x25mm fans (2 each side).
    Could you do me a favor and give me some assistance in modifying your design?
    B.r. Drayson
    Sure, how can I help?
    Hi!
    My plan is to mount two fans each side, so I thought about modifying your ducts fan mounts to have a base of 25x50mm with 8 holes for screwing the fans (holes are symetric and have a distance of 20x20mm on each fan) and cut the duct shape accordingly. Unfortunatly I'm currently out so I can't make a scetch as i'm writing on my phone :-(
    What do you think - would this be feasible? Could you give me a helping hand modifying your ducts?
    B.r drayson
    I do not know how efficient these small fans will work, but, yes, this design should be feasible in general.
    However it will be a complete redesign.
    You need a two-in-one fan duct for each side. My design cannot be modified in a simple way to support two fans unless you develope an (quite ugly) adapter that is bolted to the inlet.
    I tried something, very quick, very dirty:
    STL-File
    STP-File
    Maybe this is a suitable basis for your design.
    GREAT!! Thank you very much, thats pretty good for my tests. I'm also not sure how the fans will work so lets give it a try :-)
    B.t.w. What software do you use for modelling?
    @ Blecheimer,
    could you please do me a second favor and modify also the right one? I#d like to print both at once to test the behavior with 4 fans at the same time - the quick and dirty one is perfect :-)
    I am quite busy at the moment, so you have to wait until nex weekend. Then I can work on the right fan duct.
    As I am a professional engineer and running a small business I am using Catia V5 (for more than 14 years now) for my models. But I cannot recommend it for private use because it is very (!) expensive.
    Thank you again for your support and assistance! I really appreciate this!
    God, Catia... never used it. I learned AutoCAD and SolidWorks several years ago but had no chance to stay up to date so most of my knowledge is gone :-(
    Hello,
    I am fortunate to have a little scraped Catia V5. It's a nice tool.
    I still have a little trouble with obenir for what I want. But overall I'm doing! For cons, I'm not an engineer. I am self-taught.
    The only learning that I could get was in Autocad there a year ago.
    It's a beautiful project, your fan! At least I see that I am not alone slicer modeling in Catia.
    Alex.
    Don't know if it's useful to you, but I updated my initial design based on blecheimer's design to this new one. Not quite as pretty as Blecheimer's but fits without modification for me.
    you can grab it here:
    http://www.thingiverse.com/thing:151061
    OK, here we have the right fan duct for two 25mm fans. Again very quick, very dirty...
    STL-File
    STP-File
    Thank you Blecheimer !!!
    I will post my results as soon I have tested it.
        • 28 replies
