9 minutes ago, gr5 said:Also what kind of printer do you have? You can go with smaller nozzles. I sell 0.25mm and 0.15 and even 0.1mm nozzles for many different printer types including all the Ultimaker printers.
The problem is not buying a new nozzle. is to get Cura to properly generate proper g-code given an STL with vertical walls exactly 0.4mm thick.
gr5 2,094
I deleted your other post - they seemed identical.
As you discovered, yes you can also decrease the nozzle size. A 0.4 nozzle will typically print just as well (actually maybe better) at 0.35mm line width and will even print decently down to about 0.3mm.
Cura just doesn't do single wall width - it only prints loops. So it's always going to go over the same spot twice - sorry about that.
There is one trick you can do though - you can model your part for example as a solid cylinder and tell cura to print 0% infill. You can also disable top and/or bottom infill. This trick works with slightly more complicated shapes than a cylinder but at some point you have to go back and model the wall thickness in cad (for example if you want holes in your part other than at the top and/or bottom.
gr5 2,094
