Inventor Plugin (official thread)
thopiekar
Posted · Inventor Plugin (official thread)
5 hours ago, thopiekar said:
Sure, I can. Because of my job, I'm in Canada and doing recently many overhours.
By next week I'm back home in Germany where I will have a bit more than a week of leave because of the overhours of the whole trip.
Please keep in mind that this plugin is community supported and free software.
Thanks!
Ok, thanks!
BTW the github repo seems to be quite outdated, and your gitlab installation is not properly configured so it is impossible to send pull requests, so it does not seems very easy to contribute.
As far as I saw, the error is something with the mime type but didn't explored beyond that, 3.4 is good enough for now :)
    Posted (edited) · Inventor Plugin (official thread)
    I know. Often I just have a minimum of time, so I have to set priorities very tight and skip mirroring the sources to GitHub.
    Edited by thopiekar
    New testing version 0.2.3 backed at Detroit's airport.
    The testing version can be downloaded for testing at this location:
    https://thopiekar.eu:46380//sharing/mEcHF2wHz
    Please test and give at least a short feedback about how it works or whether at all.
    Thanks and enjoy!
    Edited by thopiekar
    I was able to install the plugin, but when I tried to open an Inventor part I got an error that said "Cannot open files of the type ... ipt." I am trying to open in Cura 3.5. Your previous plugin worked great in 3.4.
    Thanks and enjoy!
    Thanks, but it gives the same error as before.
    This is the log:
    2018-10-07 22:30:36,867 - WARNING - [MainThread] cura.PrintInformation.setBaseName [369]: Unsupported Mime Type Database file extension new.ipt
    Sorry to hear this guys.
    Looked at the code as I landed in the Netherlands. I see no reason why it shouldn't be registered.
    Will look into it soon closely.
    Thank you for testing!
    Found something I missed to change. It was something really minor, but, yeah, that made the difference.
    The SolidWorks plugin was more challenging.
    You will find the new testing release in the previous URL and please let me know whether it runs.
    So, if it does, I can push it out for all of you into the Toolbox.
    Thanks!
    I am still getting the same error as before. Cura is telling me that it cannot open files of that type. I am trying to open an Autodesk Inventor ipt file from Inventor 2016. I tried your v4 and v5 package. Is there something specific I should check for. Maybe I am doing something wrong.
    Same error here. Inventor 2018 installed, not working with inventor 2017/2018 files.
    Hmm, in my case the plugin is up and running.
    Can you please do the following:
    * Go into the configuration directory of Cura and remove there the cura.log file, while Cura is closed.
    * Retry
    * Close Cura
    * Upload the log here.
    Thanks!
    Edited by thopiekar
    The plugin is running/loading, I get the same option as you, but it does not open the files.
    Try with any inventor file, they all fail to load.
    Edited by eried
    Oh, ok. Thought it is completely crashing on your computer.
    Please follow:
    * Retry
    * Close Cura
    Thanks!
    Hint: You can find the configuration directory via Cura itself:
    OK, search for
    new.ipt
    in the log
    cura.log
    Maybe the same mistake as here
    Try Windows hard disk (C)
    Well, looked into the log and I'm pretty sure I corrected the plugin API number yesterday. However, looked into the package again and it mentions the value 4, but should be 5, which I'm pretty sure I set.
    However, trying it again. No idea how it happened.
    Yay! The last version that you uploaded 10 mins ago to: https://thopiekar.eu:46380//sharing/mEcHF2wHz works perfectly! thanks!
    I just installed your latest build and it is working great. I was able to open both an IAM (assembly file) and an IPT (part file). Thank you for working so hard on fixing this plugin.
    Beautiful. Will push this one for a review by Ultimaker then.
    Thanks!
    I don't know but the plugin is not working as before :( now it takes a long time and sometimes it say for bigger files = invalid file.
    Is ultimaker breaking the plugin system?
    Hmm, the plugin system shouldn't be the problem. There is something going wrong behind the scenes of the plugin.
    You already know how to attach a log to your message here, right?
    Make sure you remove it, reproduce the problem and attach it here then.
    Thanks!
    When using Cura 4.0.0, I have installed the plugin via the new marketplace window. When trying to open an Inventor 2018 file, it says: "Invalid File: Failed to load *insert part directory (not what it actually said here, just where the file was)*"
    This is what the log said:
    2019-04-04 08:29:50,402 - DEBUG - [Thread-4] CuraInventorPlugin.CadIntegrationUtils.CommonComReader.startApp [25]: Calling Inventor.Application...
    2019-04-04 08:29:50,402 - DEBUG - [Thread-4] CuraInventorPlugin.CadIntegrationUtils.CommonComReader.startApp [27]: CreateActiveObject..
    2019-04-04 08:29:50,406 - DEBUG - [Thread-4] UM.Logger.logException [84]: Exception: Getting active object without Coinit failed
    2019-04-04 08:29:50,410 - DEBUG - [Thread-4] UM.Logger.logException [88]: Traceback (most recent call last):
    2019-04-04 08:29:50,413 - DEBUG - [Thread-4] UM.Logger.logException [88]:   File "C:\Users\65599\AppData\Roaming\cura\4.0\plugins\CuraInventorPlugin\CuraInventorPlugin\CadIntegrationUtils\CommonComReader.py", line 31, in startApp
    2019-04-04 08:29:50,416 - DEBUG - [Thread-4] UM.Logger.logException [88]:     options["app_instance"] = ComConnector.CreateActiveObject(options["app_name"])
    2019-04-04 08:29:50,419 - DEBUG - [Thread-4] UM.Logger.logException [88]:   File "C:\Users\65599\AppData\Roaming\cura\4.0\plugins\CuraInventorPlugin\CuraInventorPlugin\CadIntegrationUtils\ComFactory\PyWin32Connector.py", line 22, in CreateActiveObject
    2019-04-04 08:29:50,422 - DEBUG - [Thread-4] UM.Logger.logException [88]:     return win32com.client.GetActiveObject(app_name)
    2019-04-04 08:29:50,424 - DEBUG - [Thread-4] UM.Logger.logException [88]:   File "C:\Users\65599\AppData\Roaming\cura\4.0\plugins\CuraInventorPlugin\CuraInventorPlugin\CadIntegrationUtils\3rd-party\cpython-3.5-windows-amd64\PyWin32\win32com\client\__init__.py", line 79, in GetActiveObject
    2019-04-04 08:29:50,426 - DEBUG - [Thread-4] UM.Logger.logException [88]:     dispatch = pythoncom.GetActiveObject(resultCLSID)
    2019-04-04 08:29:50,428 - DEBUG - [Thread-4] UM.Logger.logException [88]: pywintypes.com_error: (-2147221021, 'Operation unavailable', None, None)
    2019-04-04 08:29:50,429 - DEBUG - [Thread-4] CuraInventorPlugin.CadIntegrationUtils.CommonComReader.startApp [37]: CoInit..
    2019-04-04 08:29:50,432 - DEBUG - [Thread-4] UM.Logger.logException [84]: Exception: Getting active object with Coinit failed
    2019-04-04 08:29:50,434 - DEBUG - [Thread-4] UM.Logger.logException [88]: Traceback (most recent call last):
    2019-04-04 08:29:50,436 - DEBUG - [Thread-4] UM.Logger.logException [88]:   File "C:\Users\65599\AppData\Roaming\cura\4.0\plugins\CuraInventorPlugin\CuraInventorPlugin\CadIntegrationUtils\CommonComReader.py", line 40, in startApp
    2019-04-04 08:29:50,438 - DEBUG - [Thread-4] UM.Logger.logException [88]:     options["app_instance"] = ComConnector.CreateActiveObject(options["app_name"])
    2019-04-04 08:29:50,440 - DEBUG - [Thread-4] UM.Logger.logException [88]:   File "C:\Users\65599\AppData\Roaming\cura\4.0\plugins\CuraInventorPlugin\CuraInventorPlugin\CadIntegrationUtils\ComFactory\PyWin32Connector.py", line 22, in CreateActiveObject
    2019-04-04 08:29:50,442 - DEBUG - [Thread-4] UM.Logger.logException [88]:     return win32com.client.GetActiveObject(app_name)
    2019-04-04 08:29:50,444 - DEBUG - [Thread-4] UM.Logger.logException [88]:   File "C:\Users\65599\AppData\Roaming\cura\4.0\plugins\CuraInventorPlugin\CuraInventorPlugin\CadIntegrationUtils\3rd-party\cpython-3.5-windows-amd64\PyWin32\win32com\client\__init__.py", line 79, in GetActiveObject
    2019-04-04 08:29:50,447 - DEBUG - [Thread-4] UM.Logger.logException [88]:     dispatch = pythoncom.GetActiveObject(resultCLSID)
    2019-04-04 08:29:50,450 - DEBUG - [Thread-4] UM.Logger.logException [88]: pywintypes.com_error: (-2147221021, 'Operation unavailable', None, None)
    2019-04-04 08:29:50,450 - DEBUG - [Thread-4] CuraInventorPlugin.CadIntegrationUtils.CommonComReader.startApp [46]: UnCoInit..
    2019-04-04 08:29:50,451 - DEBUG - [Thread-4] CuraInventorPlugin.CadIntegrationUtils.CommonComReader.startApp [49]: Trying to get new class object..
    2019-04-04 08:29:53,170 - DEBUG - [MainThread] cura.AutoSave._onTimeout [48]: Autosaving preferences, instances and profiles
    2019-04-04 08:29:55,902 - DEBUG - [Thread-4] CuraInventorPlugin.CadIntegrationUtils.CommonReader.readOnSingleAppLayer [152]: ... and opening file.
    2019-04-04 08:29:55,975 - ERROR - [Thread-4] UM.Logger.logException [84]: Exception: Failed to export using 'Inventor.Application'...
    2019-04-04 08:29:55,977 - ERROR - [Thread-4] UM.Logger.logException [88]: Traceback (most recent call last):
    2019-04-04 08:29:55,979 - ERROR - [Thread-4] UM.Logger.logException [88]:   File "C:\Users\65599\AppData\Roaming\cura\4.0\plugins\CuraInventorPlugin\CuraInventorPlugin\CadIntegrationUtils\CommonReader.py", line 278, in readOnMultipleAppLayer
    2019-04-04 08:29:55,982 - ERROR - [Thread-4] UM.Logger.logException [88]:     scene_node = self.readOnSingleAppLayer(options)
    2019-04-04 08:29:55,984 - ERROR - [Thread-4] UM.Logger.logException [88]:   File "C:\Users\65599\AppData\Roaming\cura\4.0\plugins\CuraInventorPlugin\CuraInventorPlugin\CadIntegrationUtils\CommonReader.py", line 153, in readOnSingleAppLayer
    2019-04-04 08:29:55,986 - ERROR - [Thread-4] UM.Logger.logException [88]:     options = self.openForeignFile(options)
    2019-04-04 08:29:55,989 - ERROR - [Thread-4] UM.Logger.logException [88]:   File "C:\Users\65599\AppData\Roaming\cura\4.0\plugins\CuraInventorPlugin\CuraInventorPlugin\InventorReader.py", line 127, in openForeignFile
    2019-04-04 08:29:55,991 - ERROR - [Thread-4] UM.Logger.logException [88]:     options["document"] = options["app_instance"].Documents.Open(options["foreignFile"], False)
    2019-04-04 08:29:55,995 - ERROR - [Thread-4] UM.Logger.logException [88]:   File "<COMObject <unknown>>", line 3, in Open
    2019-04-04 08:29:55,998 - ERROR - [Thread-4] UM.Logger.logException [88]: pywintypes.com_error: (-2147352567, 'Exception occurred.', (0, None, None, None, 0, -2147024809), None)
    2019-04-04 08:29:56,077 - DEBUG - [Thread-4] CuraInventorPlugin.CadIntegrationUtils.CommonComReader.postCloseApp [71]: postCloseApp..
    2019-04-04 08:29:56,077 - DEBUG - [Thread-4] CuraInventorPlugin.CadIntegrationUtils.CommonReader.readOnMultipleAppLayer [299]: Scene node is None. We had no luck to use any of the readers to get the mesh data!
    2019-04-04 08:29:56,080 - WARNING - [Thread-4] UM.Mesh.MeshFileHandler.readerRead [58]: Unable to read file //htcms06/65599$/Documents/Inventor/Glider Hook.ipt
    2019-04-04 08:29:56,081 - DEBUG - [Thread-4] UM.FileHandler.ReadFileJob.run [69]: Loading file took 5.7 seconds
    Actually, nevermind. I opened a file I was sure was made in Inventor 2018 and it opened fine.
    No problem 🙂 Grad to hear that it works!
    Dear community,
    here are some updates! 🙂
    I began to clean up a lot of code in the common library called CadIntegrationUtils (CIU).
    At the moment I've got a test application working for the Inventor plugin, which only was provided with the SolidWorks plugin:
    Additionally, I added a popup message including a button which brings you to this window, so you can see where your Inventor installation might be broken.
    Along with these changes, I noticed that the code could be organized much better, so I will keep track of getting it cleaner.
    Getting this functionality working with the Inventor and SolidWorks plugin at once, will be the next step.
    Regards!
    - Thomas Karl Pietrowski
    PS: Work done: https://thopiekar.eu:5443/cura-cad-integration/CuraInventorPlugin/-/jobs/1278/artifacts/browse
    Edited by thopiekar
    Hi!
    Is there any update on when could we expect these integration plugins to work in 4.4?
