You don't have to wait for the next release. I have created a theme based on @whiteglint's tinkering that is (fairly) easy to add to your current install, and should survive future installations of Cura (unless you remove your configuration folder).
* Go to https://gist.github.com/fieldOfView/6313ca39f5e3a57b35a676fc5fd2ef63 and use the "raw" button to download the theme.json file
* Launch Cura and go to Help -> Show configuration folder
* Navigate to the folder named "themes" and create a new folder inside that folder named "compact-sidebar" (or similar)
* Place the downloaded theme.json file inside that new folder
* Restart Cura and open the preferences; there should now be a theme named "Compact sidebar"
* Select "Compact sidebar" and restart Cura one last time
whiteglint 4
THANK YOU^1000 I edited the "sidebar" region of theme.json (attached, just change the extension to .json or open in a text editor) and almost doubled the size AND inadvertently covered up that stupid "check compatibility" link that takes up a ton of precious screen real estate. Now I can actually use 3.2 if I can get it to stop changing my filament diameter to 2.85
theme.gcode
nilrog 103
Please try to put this into the next release
