Thanks for the prompt response.
I'm not doing anything different. All I did was load a new roll of ABS black. I'm printing the same part, and didn't touch any of the settings. In fact, it was only minutes between printing my last part and loading the new roll of ABS, and stated printing the same part again.
I forgot to mention in my original post; I reloaded what I had left on the old roll and did a print of the part without issue. Reloaded the new stuff and the adhesion issue returned.
I've printed a large number of parts over the years and never had to use adhesive, just clean glass. Almost allows I had to let the plate cool down before I could get the part off. But,I may need to start using glue as you suggest.
gr5 2,243
Are you printing larger parts than before? Did you re-level? Changing the z=0 (leveling) by just a tiny bit makes a huge difference in how well parts stick. more details here:
You should be using either extra thin pva glue or "abs juice" (google it) and never print ABS on a clean glass if you want it to stick well. More info about making your parts stick here in my long but very detailed and informative video:
