I'm new to Cura. I'm running Cura 3.6 from the appimage (Ultimaker_Cura-3.6.0.AppImage) on Ubuntu 18.04 and I also don't have a play button. I do not have compatibility mode forced in the General settings. As far as I can tell OpenGL is enabled and the few tests that I've tried all work. Could this be because I'm running from the appimage and the necessary libraries are missing?
burtoogle 515
Your display is in compatibility mode and the simulation isn't supported in that mode. Either you have forced compatibility mode in the preferences or your computer hw/sw does not support the required version of OpenGL. I hope this helps.
Mateus Abreu 1
GoTeNsan 0
That was unchecked "Force layer view compatibility mode". My GPU doesn"t support the required version of OpenGL.
