Search on Youtube for mould making and casting. There are a lot of companies promoting their materials with how-to videos. From there you can find their company websites and product specs.
In the Netherlands in Amsterdam, there is a big shop for modeling, moulding and casting materials and tools. They have it all: clay, plasticine, plaster, silicones, lots of composites, colors, etc... And they have downloadable catalogs with some explanation. See: https://www.formx.nl/
Maybe this could give some inspiration?
JohnInOttawa 104
I think your epoxy option might be good.
You can get epoxies with the viscosity of water and control the color with additives. In my part of Canada, West System epoxy is available in a wide array of consistencies and hardness, I was able to find one that was fluid enough and had a long enough setting time that I could allow it to soak into spalted maple and fill the internal cavities before setting. Color control was easy with this stuff as well, I needed to match surrounding wood grain and was able to use simple dried out, used coffee grounds. They dissolved beautifully and the result was flat and solid, with enough give to absorb wood movement without inducing stress along the bonds.
If you do go the epoxy route, it might be easier to coat the surfaces you don't want epoxy on with a release agent, then you can fill the inlays without worrying about staining.
Not sure if that's an option where you are, but hopefully this give you an idea.
Cheers
John
